Screenmaker Version
yu1988
in ScreenMaker
Hi guys,
Anybody knows is there a way to update screenmaker in order to make its version same with controller. I got below error when trying to deploy.
I have tried to create a robot with 6.09.00 in order to match controller version (6.9.0.0). But now i realize that the screenmaker version also have to match with controller.
Thanks in advance to support me
Hi guys,
I already solve the issue of version.
I deployed the screenmaker (Just 1 page) into virtual controller and it is work because i can see the app in at top left of screen.
But problem is, when i connect to real robot controller, deploy and restart controller. I can't see the application. Does anyone can help me on this?0 -
You need to restart the FlexPendant. There is a button on the back of the Pendant. Or unplug the pendant. It will power down. Then plug it back in. This will restart it. Or cycle power on the controller.0
- 367 IRC5
- 858 RAPID Programming
