How Can I Deactivate SafeMove
in IRC5
I have 2 controllers IRC5, I don't use SafeMove
But one, It is working now, and I a trying to configure another, I have seen the controller that is working and the Safe Move Board is disconnected, and the menu in the flexPendant doesn't have the option SafeMove Visualizer
I have disconnected the SafeMove Board in the another IRC5, but in the menu shows the option SafeMove Visualizer yet,
When I want to move the Robot in the FlexPedant appears
Eveent Message 90206
General Stop open
Description:
The General Mode Safeguarded Stop circuit has been broken.
Consequences:
The system goes to the General Stop status.
Help Me Please
General Stop open
Description:
Consequences:
Help Me Please
Rebuild the system in robotstudio, modify it, removing safemove option.Lee Justice1
How can I do that, I am trying to do it, but I need to add a license,
It is necessary to activate but i have deactivate that option.
Am I doing it in a correct way?
Help me Please, Sorry If my English is not good0 -
Are you building from backup or starting new system in RS? Build from backup.Lee Justice1
I was starting new system, but I could do it, It does not appears the SafeMove Visualazer Option in the flexpendant, maybe it is important to disconnected the SafeMove Board, too.
Now, I have this problem when I tried to move the robot, I have disconnected all wires in the SafeMove Board. It Apppers this message
and also those leds are off
Looks like you have all jumpers in. Some are not right. I cannot read your text, it looks all jumbled here.Lee Justice1
I have another IRC5 that has the same configuration with the jumpers, so I think maybe that is not a problem
but the other is working well0 -
looking at the circuit diagram AS1 and GS1 are on the same jumper terminals 10, 11, 12.
Check the jumper to ensure it is in correctly and screws are tight.
Also that the whole X5 plug is seated correctly.
- 304 PowerPacs
- 356 IRC5
- 76 OmniCore
- 851 RAPID Programming
- 26 AppStudio
