Delete Screenmaker Installed Screens
Hello All,
Can anyone tell me how to uninstall or delete an installed screen from screenmaker?
In either a Virtual Station Or a Real Controller.
Thanks In Advance
  • Now I see where to delete it from the Virtual Station, from the HOME Folder in the system files.
    But can't do this with the pendant using the "FlexPendant Explorer" screen.  So I am assuming that I can't do that with a Real Pendant either.
    So I am guessing that I would have to be connected to the real controller and use FIle Transfer to delete a real- screen.
  • Micky
    Micky ✭✭✭
    you can use the "File transfer" in the "Controller" ribbon in RobotStudio to delete your Screenmaker DLL files in the Home-Directory of a real controller.
    Afterward, you have to reset the FlexPendant via the reset button on its backside or you have to switch off and on the controller.
    A warm start of the controller will not exchange the DLL on the FlexPendant.
  • Thank You Sir, You Are A Gentleman And A Scholar.
