Event routine not starting
I am having some trouble with event routine. The routine itself is as follows:
MODULE user (SYSMODULE)
    VAR wzstationary worldzone1;
    VAR wzstationary worldzone2;
    VAR num testnum:=0;
    PROC WZPos()
      VAR shapedata shape1;
      VAR shapedata shape2;
      CONST pos corner1:=[455,200,650];
      CONST pos corner2:=[1050,-600,1100];
      CONST pos corner3:=[350,150,150];
      CONST pos corner4:=[1000,-150,600];
      testnum:=5;
      WZBoxDef \Inside,shape1,corner1,corner2;
      WZDOSet \stat,worldzone1 \Inside,shape1,doBusySlabi,0;
      WZBoxDef \Inside,shape2,corner3,corner4;
      WZDOSet \stat,worldzone2 \Inside,shape2,doBusyTrak,0;
ENDMODULE
The problem is that the routine WZPos doesn't start. I think the worldzones are defined correctly, but the routine itself doesn't execute. It is linked with a POWER_ON event in controller configuration (see attachment).
Does someone know what could be the reason for this happening?
Thank you for all your help,
Regards
  • Try to call the routine after boot up.  See if you get an error more or less like "world zone already in use or activated".
    Lee Justice
  • jled
    jled
    edited October 2019
    I tried and that is exactly what happens.
  • OK, so that tells us that it did run.  You need to get motors on for the system to recognize the zones.
    Lee Justice
  • Thank you very much!  :)
