Default Move to home Procedure is an empty list
Is your rHome Proc declared a Local Proc or normal Proc?
LOCAL PROC() ! This procedure can only be referred to inside the module it have been declared too. ! Note "LOCAL" in front of PROC() ENDPROC PROC() ! This procedure can be referred to anywhere where it is required. ! Note no "LOCAL in front of PROC() ENDPROC0 -
PROC rHome()MoveAbsJ jHome\NoEOffs, v300, fine, tWeldGun;ENDPROC0
did you sync your rHome to your station?
Ops...
my mania of removing "useless" things.. 0
- 858 RAPID Programming
