dsqc 327A
duesentrieb66
edited November 2019 in Robot Controller
Hi all,
I can't get my digital I/O working. Analog runs fine.
analog:
-Name "A1_Drive_Speed" -SignalType "AO" -Unit "BOARD10" -UnitMap "0-15"\
      -Access "All" -EncType "UNSIGNED" -MaxLog 300 -MaxPhys 10 -MaxBitVal 65535
This works fine. I get the analog value on the exit of the PLC exactly what I expect.
digital:
-Name "do_SpindleFan" -SignalType "DO" -Unit "BOARD10" -UnitMap "37"\
      -Access "All"
Robotstudio and Flexpendant update correct. But Nothing happens on the PLC, no LED.There are 2 x 10 pin connectors for out put but really not sure how to use them when there are 16 digital output. Is pin 9 and 10 of the first connector empty or is this bit 10 and 11 of the PLC?
Nothing is connected to the PLC on the  DI/O or analog. The 2 led are green. When I hock up an ohm meter I can see some changes happening but make no sense to me (switches between 5MOhm and 2MOhm or so), so something is happening. Also no error message nowhere. Also I can't find any manual for the 327A or 328A.
Any help is much appreciated,
Thanks!
  • You need to connect 0 V to pin 9 and 24 VDC to pin 10 - then the LED's will work as well as getting 24 VDC on the output.
    See attached pin outs for the board.
  • duesentrieb66
    Thanks graemepaulin. This did the trick!
    And this is the document I was searching for!!
