Set/Reset or SetDO?
Paba
Is there a big difference from these instructions when changing the value of a digital output?
except for the 2 arguments \sDelay & \Sync i couldnt find any ..
i'm just asking for interest
No there is no big difference. The Set/Reset instruction is a newer version. I think the SetDo is a relic.
Ok thanks, i just wanted to be sure:)
SetDO has more timing options. Set and Reset are simple turn on / turn off.0
SetDo is great when you don't know if you want to set the output high or low, but you have it stored in a dionum variable.
That way you can write:
SetDO <output>, <variable>;
Instead of:
IF <variable>=1 THEN
Set <output>;
ELSE
Reset <output>;
ENDIF
//Markus Näslund0
