Is it possible to call inside de C# program (PC SDK) a procedure with several parameters/arguments?
Inside RobotStudio I have:
MODULE MAR
PROC MAR_T(bool b0, bool b1, bool b2, bool b3)
ENDMODULE
Inside de C# program (PC SDK) I can execute the procedures inside the RobotStudio but these procedures does not have any parameters.
Once Auto is OK, mastership is OK, the following sentence execute any routine without parameters:
task.TaskName.SetProgramPointer(_moduleName, auxRoutine.Name);
How can I send the boolean parameters I have to send (about 8 boolean)?
You can only call routines without parameters.
If you want to use certain parameters, you can write the required values in Persistent data declaration before calling a routine and query the values in the RAPID routine0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
