Function to determine controller version
lemster68
I know that there are functions to determine RobOS vs. VC, but is there a function to determine the version of controller? S4, S4C+ or IRC5? If not,could we maybe get one? Please, pretty please with sugar on top?
Lee Justice
Hello,Have you test this:
VAR string version;<br> version := GetSysInfo(\SWVersion);
Rapid Tech Manual
2.85 GetSysInfo - Get information about the system UsageGetSysInfo is used to read information about the system. The available informationincludes serial number, software version, software version name, robot type,controller ID, WAN IP address, controller language, and system name.0 -
I don't think that that instruction was available in pre IRC5 controllers. Maybe not even in early IRC5. I am not concerned with the version, but the controller version inself. But thank you anyway.Lee Justice0
Or you can call procedures using late binding (%%)?Not really clean but should works.You can find new procedure in each release notes.
- 398 UpFeed
- 300 PowerPacs
- 336 IRC5
- 67 OmniCore
- 828 RAPID Programming
- 12 AppStudio
