RobotStudio Silent Install
I need to install RobotStudio on a couple of PCs in our students lab. Is there a possibility to define the target dir and the path to the license server for a silent install? I managed a silent install with basic parameters using the command line
setup.exe /S /v/qn
But this is rather useless if i have to define the license server on each pc afterwards. I looked through the readme of RobotStudio and also through the manual, didn't find anything...
Regards
Matthias
  • Hi Matthias,
    Try this:
    setup.exe /s /v"/qb ADDLOCAL=ALL LICENSE_SERVER=myhostname"
    It might be possible to change target directory by adding INSTALLDIR=... inside the quotes, but that has not been tested.
    Regards,
    Johannes
    Johannes Weiman
    RobotStudio Team, ABB Robotics
  • Dear Johannes,
    thanks to your post, we were able to deploy RobotStudio 6 on our clients with a defined license server.
    After upgrading to Version 7 (2019), the setup parameter "LICENSE_SERVER=myhostname" has stopped working and we have
    to manually define the license server on every client.
    Do you know if the setup parameter has been changed?
    Kind Regards,
    Markus
  • Hi Markus,
    Yes it is not working in 2019.1 due to changes in the licensing system. This will be addressed in 2019.2 which should be released soon.
    A workaround is to run this command as a separate step after the installation:
    RobotStudio.Installer.exe SetServer myhostname
    RobotStudio.Installer.exe is located in the RobotStudio 2019\Bin directory. Note that it requires elevated privileges.
    Johannes Weiman
  • Dear Johannes,
    thanks for the hints for the silent install. Is there a documentation of all possible command line options/operations?
    Is it also possible to install RobotWare silently? When switching to RS 2019 we need to make the change on numerous workstations, so this would really help.
    Regards
    Matthias
  • Hi Matthias,
    Besides LICENSE_SERVER, there are only standard InstallShield switches:
    https://helpnet.flexerasoftware.com/installshield19helplib/helplibrary/IHelpSetup_EXECmdLine.htm
    I don't think it's possible to install RobotWare silently, but I'll make a note of it.
    Johannes Weiman
  • Hi Johannes,
    thanks for the information. Would be good to have the RobotWare installed automatically, but so we have to do it manually. More work for our student assistants ;-)
  • Just wanted to confirm that the silent installation procedure outlined above works with RobotStudio 2020.x
    Maxim Riabichev
    PC Software Support Engineer
