Error handler during EGM
csmith
csmith
edited January 2020 in RAPID Programming
I'm trying to recover from any motion errors while my robot is controlled through EGM.
My current Rapid code:
TEST egm_action
    CASE EGM_POSE:
        printInfoMessage 1, CONTEXT_EGM, "Starting pose mode";
        EGMRunPose egm_id,
            EGM_STOP_HOLD,
            \X \Y \Z \Rx \Ry \Rz
            \CondTime:=20
            \RampInTime:=0.1
            \PosCorrGain:=1;
    DEFAULT:
ENDTEST
    EGMReset egm_id;
ERROR
    IF ERRNO=ERR_ROBLIMIT THEN
        TPWrite "Joint out of range error";
        MoveAbsJ homepos,v100,fine,tool0;
    ENDIF
Whenever I run into an Error during EGM, my error handler won't execute.
How can I make this work so I can recover without manually jogging the robot back to a valid position?
Thank you
  • Check out the system input Interrupt.  If you have an error, your system output for error can tell the PLC that there is a problem.  Then the PLC can give you that system input. From what I understand, it will act on that without the program running.
    Lee Justice
