Can I move a robot just by specifying a joint and an angle?[Moved]
laov
laov
edited February 2014 in Robot Controller
I would like to know if its possible to move a robot just by specifying a joint and an angle? Position coordinates being irrelevant and undefined in this move instruction.
Post edited by Jonathan Karlsson on
  • Thank you for your reply that really helped.
  • How to change single joint value of specific joint?
    joints :=  CJointT();
    Say, if I would like to change the 5th joint value of above joints variable, what is the syntax?
  • to change axis 5 to 15° as below:
    joints.robax.rax_5:=15;
