Add ethernet/IP option / Connect IRC5 to PLC
WALL_E
Hi everyone
Before I start, I just wanted to let you know that I'm not 100% familiar with the RobotStudio environment and that I'm still new in that domain (Sorry in advance if my problem seems silly).
So I have an IRC5 controller with the DeviceNet Master/Slave option, but I also need to set up a connection between my controller and a PLC (with Sysmac Studio).
In the Configuration - I/O system tab I can see in the industrial network section that I have the DeviceNet but I'm pretty sure I also need the Ethernet/IP anybus option.
So my questions are:
-Do I really need this option for my application?
-If yes, do I need a license key like, for instance, the multitasking option?
Thank you
Thank you
Look in the backinfo folder for the backinfo.txt file, it will list your options. If you don't have ethernet/IP option then you will need to buy it and they should give you a new keystring.Lee Justice1
