Force control for a Grinding application
HI,
Am working on a project with force Control to do a grinding operation ( IRB 4600, IRC5 controller, Robotware_6.09.0154)
when the grinder turned on my force value is fluctuating, it goes like -200 to 200N(in mid air)
how do i stabilize this?
Did i miss anything ? please help me correct this.
var num nforce;
var num nAngleY;
nforce=10
TempLoad:=FCLoadID(\LoadidErr:=nFcloadErr);
FCCalib TempLoad;
!Grinder On
FCPress1LStart reltool(Apoint,0,0,0\Ry:=nAngleY), v20\Fz:=nForce, 80\ForceFrameRef:=FC_REFFRAME_WOBJ \ForceChange:=50 \DampingTune:=100 \TimeOut:=5 \UseSpdFFW,\PosSupvDist:=10, z1, t4inGrinder\WObj:=WbjGrind;
FCPressL reltool(ABpoint,0,0,0\Ry:=nAngleY),v20,nForce,z1,t4inGrinder\WObj:=WbjGrind;
FCPressL reltool(Bpoint,0,0,0\Ry:=nAngleY),v20,nForce,z1,t4inGrinder\WObj:=WbjGrind;
FCPressEnd rGrindingEnd_1,v50\DeactOnly,t4inGrinder\WObj:=WbjGrind;
!Grinder Off
And to check the force real time am using the instruction Fcgetforce(\contact force)
Thank you
I think you need to add identify the load and calibrate, from the Force Control manual the basic approach to creating a program is:
1 Identify the load.
2 Move to a point close to contact but not in contact.
3 Calibrate.
4 Setup force control directions and start movement.
5 Move linear or circular with contact.
6 Leave surface.Example below is with force Z with a movement in x-direction
PROC press1()
PERS loaddata TestLoad:=[0.001,[0,0,0.001],[1,0,0,0],0,0,0];! Identify the load using the sensor
TestLoad:=FCLoadID();! Move close to contact
MoveJ offs(B,0,0,2) , v100, fine, tool0; !! start 2mm above contactpoint! Calibrate the force sensor
FCCalib TestLoad;! Approach surface and start move to robtarget C at 50% of
! 60 N i.e 30 N
FCPress1LStart C, v100, \Fz:=60, 50, z30, myTool;! Move Linear from C to D1 with a Force of 50 N in the z-direction
FCPressL D1,v100,50,z30,myTool;! Move Linear from D1 to D2 with a Force of 70 N in the
! z-direction
FCPressL D2,v100,70,z30,myTool;! Leave surface and move to robtarget E, Force control
! is disabled after this instruction
FCPressEnd E, v100,myTool;
ENDPROC0 -
I understand this part, my problem is when i turned on the grinder in force value is fluctuating drastically because of that when i tried applying constant force robot is going in random direction.0
You should have the grinder running before doing the calibration.
yes it worked , Thankyou0
- 348 IRC5
- 845 RAPID Programming
- 21 AppStudio
