SmartComponentCodeBehind.OnInitialize Method
DenisFR
Could someone explain me this methods?
I cannot get it working. Never called.☑️2024 - RobotStudio® User Group
Up☑️2024 - RobotStudio® User Group0
Hello Denis,
Have you see this reference: http://developercenter.robotstudio.com/blobproxy/devcenter/RobotStudio/html/34d33a0a-01ab-465d-93ac-cab319cac46e.htm
I can't explain that method, but perhaps you'd want to use the OnLoad method instead?Post edited by Maxim Riabichev on
Hello @Maxim Riabichev ,Thanks a lot.No I haven't see that. Should be added to 'See Also' section.Could someone review my codes in https://github.com/DenisFR all RS repos.So they could be added to example.☑️2024 - RobotStudio® User Group0
Hello Denis,
In regards to SmartComponent examples, have you seen this post: https://forums.robotstudio.com/discussion/12091/finding-example-code-for-building-smartcomponents
I will have a look at your code when I get some spare time
Hello,I didn't know this software.I'll have a look at this ASAP.ThanksMaybe I've found some guidance for this topic:
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
