How to modify Voltage on IRC5
nibo01
We want to modify the voltage of our controler (IRC5) - 480 V - 3 Phases to 600 V - 3 phases. How can we do it? Can we use another jumper configuration in the controller to have 600 V????
thanks
Nick
Nick B.
Hi Nick,
It is not so difficult to do. but you need to be careful.
Followings are described based on Small size robots such as IRB1400, 2400. Circuit for bit robots is a bit different.;
You just open a steel cover, back & buttom side of the controller.
then You can see the Transformer and Terminals for Mains voltage setting. Change the mains cable.(Wire number: 113,114 and 115)
The pictures attached will help you. For further information, See the Circuit Diagram of IRC5.2006-12-06_010640_IRC5_TR.zip
Thanks.
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
