Duty Time Counter over robot web service
Wan
Wan
edited January 2020 in Developer Tools
how can i get the duty time counter over robet web service ? (RobotWare 6)
Post edited by Wan on
  • Hi
    You need to implement a RAPID routine which call sCounter = GetServiceInfo(ROB_ID\DutyTimeCny)
    and get that info thru
    http://<Robot IP add>/rw/rapid/symbol/data/RAPID/T_ROB1/<RAPID Routine Name>/sCounter?json=1'
    Hope it helps
  • sanlop said:
    Hope it helps
    The results show that  symbol was not found,what should I do
  • For RW 6
    http://localhost/rw/devices/HW_DEVICES/MECH_UNITS/ROB1/SIS_DATA_ROB1/PROPERTY_PRODTIME_R1
