Jogging Robot in User Defined Increments
I have been searching online for a way to jog the robot in user defined increments. For instance, if I want to jog in increments of 25.4mm at a time, or 50.8mm at a time, etc etc. Is this possible? If so, how to I implement this?
  • Hello,
    In IRC5 version, increment value can be between 0.0 and 5.0.
  • DenisFR said:
    Is it possible to exceed 5.0? Or is that the max?
  • That's the max.
