Move indipentently one external axis
Hello i've a robot that has 2 external axis. The problem is the cleaning guys in the night always move "manually" one of the external axis.
Since this robot has more than 1 homeposition i would like to have reset the position of the Axis 7 and 8 wherever the robot is.
For now i wrote this small codes but it works only for the axis 1-6. it give error with 7 and 8.
PROC Init()
PROC Init()
joint :=CJointT();
joint.robax.rax_8:=-1.30686;
Thanks.
How do you use those axes? Independent mode, coordinated or a mix of both?Lee Justice0
Look at a jointtarget in Program Data. External axes are NOT declared ... rax#
It is more likely the instruction you are looking for is:
joint.extax.eax_a (1st logical external axis - usually) :=3.14159;
joint.extax.eax_b (2nd logical external axis - usually) :=-1.30686;
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 29 AppStudio
