Mastership.Request(iMastershipResource) is obsolete
davidmaynard100
edited May 2021 in Developer Tools
In the latest PC SDK, I have a warning that "Mastership.Request(iMastershipResource)" is obsolete and should be replaced with "Request(iMastershipResourceController)".
My existing code is
public static Controller rpdController
using (Mastership m = Mastership.Request(rpdController.Rapid))
rpdTask.Start();
I'm unsure of how to replace this code with the new version and an internet search comes-up with nothing (so far :).
David
Post edited by Nils Olofsson on
  • DenisFR
    DenisFR ✭✭✭
    I don't have last PS SDK to test with it, but in its PC_SDK_Reference_Documentation.chm
    ABB.Robotics.Controllers. Controller
    is:
    public sealed class Controller : SDKBase,
    	IController, IMastershipResourceController, IMastershipResource
    Can you check it in VisualStudio?
  • Thanks, yes I can view it in VS Object Browser but am stuck with the code changes I need to make.
  • DenisFR
    DenisFR ✭✭✭
    Does this works?
    using (Mastership m = Mastership.Request((iMastershipResourceController)rpdController.Rapid))
  • Hi again, I tried this but it didn't work.
    David
  • Micky
    Micky ✭✭✭
    please try the following:
    using (Mastership m = Mastership.Request(rpdController))
  • Hi Micky
    Thank you very much, that worked.
    I only just revisited this issue since it first arose last year.
    Regards
    David
  • Hello,
    Just moved the thread into Developer Tools section so it's easier to find if someone has similar problem
    Nils Olofsson
    PC Software Support Engineer
