Rename Virtual Controller
I would like to rename some of my virtual controllers that I have in Robot Studio - I cannot seem to rename them. I have tried using installation manager 6 but it does not work.
RobotStudio 2019.5 (64-bit)
Version 7.0.8721.0594
RobotWare 6.10.01
I tried it with the installation manager 6 and it worked just fine.
RobotStudio 2019.5.2 (64-bit)
Version 7.0.8732.0594
RobotWare 6.10.02
s0847060 -
Someone else working on the same project was able to help me out. I used installation manager but I had to open and close RobotStudio a couple of times for it to figure itself out - It couldn't find the controller folder until I restarted RobotStudio.0
To maybe help someone in the future, when you open up the installation manager & try to change the controller value. The controller you are trying to rename should not be open in a station.
I got this to work by opening up an empty RobotStudio window, closing station that contained the controller, & then renaming it in installation manager.
