eio.cfg in the IRC5
I have problems to define the length of a group of inputs (eio.cfg)
with the new controller IRC5.
Someone can i help me?
Wher can i get the user guide for this controller?
Group signsal is consist of following elements; Name, SignalType, Unit, UnitMap...
and UnitMap defines the length of Group signal. See the example below. The value '0-3' are the address of each IO unit where 4 digits are defined as a Group Input, giModel. It is important that the signal address starts from zero.
-Name "giModel" -SignalType "GI" -Unit "BOARD10" -UnitMap "0-3"
2006-12-06_001446_EIO.zipFor further information, Read the Tech. Reference Manual, "System Parameters"
Good Luck!
Thank you very much innebandy
Your answer me has been of great help.
Now I have the problem to define more of a group of inputs and only me the first one works.0
