System creation failure.
Hi!
Previously I had RobotStudio ver 5.15 installed and it worked just fine.
After installing version 6.03.02 creating systems with robotware version 5.15 still works but when I try to crate a new system with ´robotware 6.03.02 I get the following error.
I have tried to uninstall all previous versions of RobotStudio and Reinstalled the latest version 6.03.02 several times with no success.
Also did the following.
- Tried to upgrade IronPython which worked for another user in a similar thread.
- Upgraded the .NET framework to 4.6.1
- Redirected Network-paths to local drive.
Please Help!
/Emil
Hello
Have you tried renaming your RobotWare folder?
1. Shut down RobotStudio
2. Go to %localappdata%\ABB Industrial IT\Robotics IT using Windows Explorer and rename the RobotWare folder (RobotWare_ for example.) RobotStudio will now create a new empty RW folder. There may be corrupt stuff in your current folder which is causing the error.
3. Start RobotStudio and try to create a system.
/Pavel1 -
I had a similar issue with 6.04.00.01 when I switched from 6.03. When I tried to load a 6.03 version Pack and Go it failed to load . Renaming this particular folder solved the issue.
Thanks for the advice!
i have a similar error with robotstudio 6.08.01 but with renaming the folder robotware i don't solve the problem.
In particular the error that i have there are when i create a new station, import a robot and creating a robotic system from the profile.
I can't create the robotic system..
I have just tryed to unistall and reinstall robotstudio, restarting windows...
Attached there are the screen error
Waiting for a reply
best regards
.I
- 351 IRC5
- 848 RAPID Programming
- 23 AppStudio
