Duty Time Counter over robot web service
Wan
how can i get the duty time counter over robet web service ? (RobotWare 6)
Post edited by Wan on
You need to implement a RAPID routine which call sCounter = GetServiceInfo(ROB_ID\DutyTimeCny)
and get that info thru
http://<Robot IP add>/rw/rapid/symbol/data/RAPID/T_ROB1/<RAPID Routine Name>/sCounter?json=1'
Hope it helps
The results show that symbol was not found,what should I dosanlop said:Hi
Hope it helps0 -
For RW 6
http://localhost/rw/devices/HW_DEVICES/MECH_UNITS/ROB1/SIS_DATA_ROB1/PROPERTY_PRODTIME_R1
