PC SDK API documentation website is down?
yfengus
When I search for “IpcQueue.Send” in Google, the first two results are from developercenter.robotstudio.com and the excerpt of the search result contains API documentation for IpcQueue.Send method. However, if I click into the search result, it will redirect to the homepage of https://developercenter.robotstudio.com/ and as a result I was not able to read the actual API documentation. Is this a known problem and is there a way around it? Thanks!
Hello.
The API Reference has been made available again!
https://developercenter.robotstudio.com/api/pcsdkApi/
Have a nice weekend!
—Maxim RiabichevPC Software Support Engineer5
The resource looks to be available again.
Please try to access it again.Post edited by Maxim Riabichev on
Curious do you mind providing an PC SDK API documentation link that works? I tried searching for "IpcQueue.Send" in Google again, and the only thing I can access is the webcache (http://webcache.googleusercontent.com/search?q=cache:l-DxpVRMx-YJ:developercenter.robotstudio.com/blobproxy/devcenter/RobotCommunication/html/35329514-6a1c-3a1a-a16e-ce4b623398d7.htm+&cd=2&hl=en&ct=clnk&gl=us), not the current API documentation. If Google decides to refresh the webcache again, I am worried that we will lose access to all PC SDK API documentations.Maxim Riabichev said:Hello,
Please try to access it again.0 -
Hello.
We are looking into this issue right now.
Thank you for reporting it!
