PC SDK API documentation website is down?
yfengus
When I search for “IpcQueue.Send” in Google, the first two results are from developercenter.robotstudio.com and the excerpt of the search result contains API documentation for IpcQueue.Send method. However, if I click into the search result, it will redirect to the homepage of https://developercenter.robotstudio.com/ and as a result I was not able to read the actual API documentation. Is this a known problem and is there a way around it? Thanks!
Hello.
The API Reference has been made available again!
https://developercenter.robotstudio.com/api/pcsdkApi/
Have a nice weekend!—Maxim RiabichevPC Software Support Engineer5
The resource looks to be available again.
Please try to access it again.Post edited by Maxim Riabichev on—Maxim RiabichevPC Software Support Engineer0 -
Maxim Riabichev said:Hello,
Please try to access it again.0 -
Hello.
We are looking into this issue right now.
Thank you for reporting it!—Maxim RiabichevPC Software Support Engineer0
- 304 PowerPacs
- 356 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 27 AppStudio
