Acis restore error 3015: 'Access violation' - when importing a .sat file
Hello! I can't import SAT anymore. What could be a quick fix for this error: Acis restore error 3015: 'Access violation'
Thanks in advance!
  • EricH
    EricH
    edited May 2020
    Could solve it with a CAD Converter. Something was broken in the Data.
  • Now it is a problem again. Lost the trial of the converter.
  • dnilsson
    dnilsson
    edited June 2020
    Do you have IronCAD installed?
    If so I know that have previously caused issues with CAD imports.
    Otherwise, I recommend you to contact the ABB support.
  • I don't have IronCAD. ABB support is contacted, but they still have no solution yet. Seems like a complicated problem.
  • daniel72
    daniel72
    edited August 2020
    Youn can try to convert in .STL with 3D-Tool Trial Version
  • I know, but we don't want to buy a license of a CAD Converter, when Robotstudio should support CAD Import.
