Move to specific height.
jthyge
Hello
I am looking for at function to move the robot to a specific height.
When robot is in a random position, i want i to move to 3000 on the y axis.
I can not find this in the RAPID documentation.
Is there at way to make this move?
Just use the cRobT instruction to determine the location where the robot is and store it as the next point.
Once the next point is determined you just need to change the Y-coordinate before moving to it.
Underneath is a same example in rapid code.
Example code:NextPos:=CRobT(\Tool:=tGripper\WObj:=wobj0);
NextPos.trans.y:=3000;
MoveL NextPos,v200,fine,tGripper\WObj:=wobj0;
jthyge said:Hello
This confuses me, Y axis is generally not height. Z is usually the height. Just how big is this robot? 3 meters is quite a distance in any direction.
Is there at way to make this move?Lee Justice0 -
Thanks Geoffrey, that works perfectly.
Lee, absolute distance.
Thanks for your answers.0 -
The other example he gave does work, but it is not the only way. As is the case many times with Rapid. What I did before to move to an absolute ceiling was like this:
pTemp:=CRobT(\Tool:=myTool\WObj:=myWobj);
MoveL Offs(pTemp, 0,0, (3000-pTemp.trans.z)), v100, fine, tool0;
3000 is the absolute ceiling and subtracting the current Z from it will always get you up to 3000.Lee Justice0 -
lemster68 said:The other example he gave does work, but it is not the only way. As is the case many times with Rapid. What I did before to move to an absolute ceiling was like this:
3000 is the absolute ceiling and subtracting the current Z from it will always get you up to 3000.0
- 341 IRC5
- 69 OmniCore
- 840 RAPID Programming
- 19 AppStudio
