RS2019.5: Fail to backup controller unpacked
On station unpacked with more than 1 controller, when I save it, controllers failed to make backups:
11223: Backup error
Description
Error during the backup of Task.
The directory lacks at least one necessary item.
Consequences
The backup request is aborted.
No backup was created.
Description
Consequences
How to reproduce:
1- Create new solution with station and virtual controller (IRB_6700_205kg_2.80m / 6.08.01.00)
2- Add new controller
3- Save (all works here)
4- Create a Pack and Go
5- Close RS
6- Open rspag file and unpack it in new target
7- Modify station by adding an empty part or else
8- Save station...
Backup failed for the two controllers.
When enabling controller to log to a console window, I've got:
C1:
[ROBRSP] <Got storage pointer 0x49fbb8a0>
Backup requested via RobAPI. Path: C:/Users/user/AppData/Local/Temp/5fab87d0, Include: 0xFFFF
20-01-17 14:08:13 MC0(barts): d:\workspaces\robotsoftware\kernel\6.08.xx\areas\systemdirector\components\bar\bar_backup.cpp 2024 Error while validating backup: -73
20-01-17 14:08:13 MC0: type = ERROR id = Operational code = 1223 (11223)
arg 0: 2 arg 1: -73 arg 2: 248
20-01-17 14:08:13 MC0: type = ERROR id = Operational code = 1261 (11261)
arg 0: C:\Users\user\Documents\RobotStudio\Solutions\TestMultiRobots2\Virtual Controllers\TEMP\1579266265\backup.085502
C2:
Backup requested via RobAPI. Path: C:/Users/user/AppData/Local/Temp/145f7c90, Include: 0xFFFF
arg 0: C:\Users\user\Documents\RobotStudio\Solutions\TestMultiRobots2\Virtual Controllers\TEMP\1579266265\backup.478386
%temp% folders are not created (maybe cleaned) only empty \Virtual Controllers\TEMP\1579266265.
☑️2024 - RobotStudio® User Group
Other case:1- Create new solution with station and virtual controller (IRB_6700_205kg_2.80m / 6.08.01.00)2- Add new controller3- Save (all works here)4- Create a Pack and Go5- Close RS6- Reopen stationOnly first controller are backed other one doesn't received Backup requested via RobAPI.7- Modify station by adding an empty part or else8- Save station...I cannot change controller operation mode either. I've got Timeout error:RobotStudio .NET exception: C0040403 : No response from controller.
Timeout
Url: Cmd:Get Prop:Mode Args: Elapsed:19991 CurrentCmds:4
History:
-00:06:35.2405879 [738] status:SYS_CTRL_S_OK data:TRUE
-00:03:02.1860638 [747] Subscribe url= prop=BackupSub arg=
-00:03:02.1860638 [748] SendCommand url: cmd:Set prop:Backup arg:-Path "C:/Users/user/AppData/Local/Temp/725301b0"
-00:02:45.4085605 [747] status:2147549183 data:Subscribe eventid error 0x0 != 0x14c34cd4 url=/127.0.0.1/ hr=0x8000ffff f=c:\bui...
-00:01:24.0191970 [754] SendCommand url:/MOTIONSYSTEM/MECHUNITS/ROB_1 cmd:Set prop:MechUnitPosition arg:-Pose 30.61856,0,0,0,30,0,0,0,0,0,0,0
-00:01:09.2044807 [757] Subscribe url= prop=BackupSub arg=
-00:01:09.2044807 [758] SendCommand url: cmd:Set prop:Backup arg:-Path "C:/Users/user/AppData/Local/Temp/2a93da9c"
-00:00:56.4711628 [754] status:ROB_E_TIMEOUT data:Timeout TIMEOUT
-00:00:56.4371349 [763] SendCommand url:/MOTIONSYSTEM/MECHUNITS/ROB_1 cmd:Set prop:MechUnitPosition arg:-Pose 30.61856,0,31.03093,0,30,0,0,0,0,0,0,0
-00:00:44.3788149 [757] status:2147549183 data:Subscribe eventid error 0x0 != 0x14c34cd4 url=/127.0.0.1/ hr=0x8000ffff f=c:\bui...
-00:00:36.2391591 [764] SendCommand url:/CONFIG cmd:Get prop:Childs arg:-mark 0 -noelts -1 -cc 0
-00:00:34.0023948 [763] status:ROB_E_TIMEOUT data:Timeout TIMEOUT
-00:00:34.0023948 [765] SendCommand url:/MOTIONSYSTEM/MECHUNITS/ROB_1 cmd:Set prop:MechUnitPosition arg:-Pose 30.61856,0,31.03093,0,63.09278,0,0,0,0,0,0,0
-00:00:32.9943479 [766] SendCommand url: cmd:Get prop:IsOptionPresent arg:-Option KLMODESWITCH
-00:00:17.6209443 [764] status:ROB_E_TIMEOUT data:Timeout TIMEOUT
-00:00:15.8135474 [765] status:ROB_E_TIMEOUT data:Timeout TIMEOUT
-00:00:14.9903327 [766] status:ROB_E_TIMEOUT data:Timeout TIMEOUT
-00:00:14.4764457 [767] SendCommand url: cmd:Get prop:Mode arg:
-00:00:11.1617891 [770] SendCommand url: cmd:Get prop:IsOptionPresent arg:-Option KLMODESWITCH
00:00:00 [767] status:ROB_E_TIMEOUT data:Timeout TIMEOUT
Base exception: RobApiException
Timeout
History:
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at RobotStudio.Services.RobApi.RobVcPanel.<SetOperatingModeInternal>d__24.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at RobotStudio.Services.RobApi.RobVcPanel.<SetOperatingMode>d__23.MoveNext()
at RobotStudio.UI.Controller.VCPanelSmall.<RadioButton_CheckedChanged>d__4.MoveNext()
Thanks for the report and the clear reproduction steps.
We'll look into this issue.
