Display image with UIMsgBox RW6.09
jmf
jmf
Hi everyone
Can someone please give me some details on how to display a image on the TP Unit with UIMsgBox and UIMessageBox.
I have followed the manual Rapid Instruction, Functions and Data Types manual but no luck.
Here my system info:
?xml version="1.0" encoding="UTF-8"?>
-<SystemProperties>
<SystemName>MMD_Africa_RW6.09</SystemName>
<SerialNo>4600-101672</SerialNo>
-<UsedMedia>
<Media version="6.09.0154" name="RobotWare" path="C:\Users\john\AppData\Local\ABB\RobotWare\RobotWare_6.09.0154"> </Media>
<Media version="6.09.0154" name="TrackMotion" path="C:\Users\john\AppData\Local\ABB\RobotWare\TrackMotion_6.09.0154"> </Media>
</UsedMedia>
-<ControlModule>
<Option descr="RobotWare Base"> </Option>
<Option descr="English"> </Option>
<Option descr="709-1 DeviceNet Master/Slave"> </Option>
<Option descr="608-1 World Zones"> </Option>
<Option descr="613-1 Collision Detection"> </Option>
<Option descr="617-1 FlexPendant Interface"> </Option>
<Option descr="624-1 Continuous Application Platform"> </Option>
<Option descr="628-1 Sensor Interface"> </Option>
<Option descr="652-1 BullsEye"> </Option>
<Option descr="653-3 ABB TSC 2013"> </Option>
<Option descr="637-1 Production Screen"> </Option>
</ControlModule>
-<DriveModule>
<Name>Robot1</Name>
<Option descr="653-x Torch Service"> </Option>
<Option descr="IRB 4600-20/2.50 Type C"> </Option>
<Option descr="Drive System IRB 460/640/660/760/4600/66xx/6700"> </Option>
<Option descr="ADU-790A in position X3"> </Option>
<Option descr="633-4 Arc"> </Option>
<Option descr="ESAB AristoMig integrated"> </Option>
<Option descr="815-2 WeldGuide MultiPass"> </Option>
<Option descr="657-1 SmarTac IO version"> </Option>
</DriveModule>
-<AdditionalOption>
<Name>TrackMotion</Name>
<Option descr="Track Motion x004 Base"> </Option>
<Option descr="IRBT 4004 Type A 10.9 m"> </Option>
<Option descr="Standard carriage In line"> </Option>
</AdditionalOption>
</SystemProperties>
Here the code I have tried:
Note. I have the image in png,gif and jpeg already in the Home Directory of the Controller.
VAR num nDummy;
VAR string sRing_5051989_Rot_Speed:="Ring5051988";
CONST string btnAcknowledge{2}:=["OKAY",""];
nDummy:=UIMessageBox(\Header:="UIMessageBox Header"\Icon:=iconInfo\Image:=sRing_5051989_Rot_Speed);
nDummy:=UIMessageBox(\Header:=""\BtnArray:=btnAcknowledge\Image:=sRing_5051989_Rot_Speed);
UIMsgBox\Header:="",""\Image:="Home:/Ring5051988"\Result:=nDummy;
UIMsgWrite "",""\Image:="Home/Ring5051988";
I just want a simple image displayed of the Current Part selected before procedure start.
Thanks in advance.
  • DenisFR
    DenisFR ✭✭✭
    Answer ✓
    Should be:
    VAR string sRing_5051989_Rot_Speed:="Ring5051988.png";
  • DenisFR
    DenisFR ✭✭✭
    Did you test:
    nDummy:=UIMessageBox(\Header:="UIMessageBox Header","Some Text"\Image:=sRing_5051989_Rot_Speed);
  • DenisFR said:
    Did you test:
    Hi.
    Just tested it and still not showing the picture.
    I did make sure the picture is to recommended size (pixels).
    Could this be because I am using it on the VC and not on the RC?
  • Cool it works thanks.
  • lemster68
    lemster68 ✭✭✭
    I had tried using UIListView in this way about two years ago, it did not work for me.
    Lee Justice
