Unknown error: ArcWeld [ArcWelding PowerPac]
Hello, i received this error "Unknown error: ArcWeld" when choosing arcweld from the Process menu of RobotStudio. We have licensed the product. Does anyone know what is wrong and how to fix it?
Cole
Cole
"Argon Technology - your industrial robotics and automation partner, helping you build your tomorrow"
In addition to my previous post i found this dump information which may provide useful to someone in the know.
RobotStudio .NET exception dump
Base exception:
Method not found: 'Boolean ABB.Robotics.RobotStudio.LicenseValidator.AcquireLicense(Sys tem.String, System.String, Boolean)'.
at ProcessPac.MainClass.LicenseValid(String Feature, String Version, Boolean Keep)
at ProcessPac.MainClass.cmd_ExecuteCommand(Object sender, ExecuteCommandEventArgs e)
at ABB.Robotics.RobotStudio.Environment.CommandBarButton.RaiseE xecuteCommand()
"Argon Technology - your industrial robotics and automation partner, helping you build your tomorrow"0 -
Hi Cole,
It seems to be a problem with the license anyway. Are you sure you have a valid license for both RS and AWPP? Do you have the same version of AWPP as RS. You can check this in "Add/Remove programs" under "support information". If you run RS5.07.01, both RS and AWPP should be version 5.07.1834.1023. Then make sure that AWPP is included in your license.
Best Regards,
__________________
Anders Jahnberg
ABB Automation TechnologiesBest regards,
Anders Jahnberg
ABB Robotics0
- 87 OmniCore
