Error
I have this error when trying to create a new workstation at robotstudio, could someone help me?
Last installed RobotStudio 2020.1 version
Error message:
Exception: Unable to load DLL 'RobotStudio.Native.Graphics.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
  • joaoeq
    joaoeq
    Answer ✓
    Hello Maxim
    Problem solved, I uninstalled the program and removed all registrations, reinstalled and it worked.
    Thank's for your time
    Best Regards
    Joao
  • My suggestion would be to uninstall and reinstall RobotStudio.
    Make sure to unzip the archive before you launch setup.exe too.
    Maxim Riabichev
    PC Software Support Engineer
  • Hi Maxim
    Thanks for answering.
    Well, I already did that and it had no effect, the same error continues.
  • What version of Windows are you using?
    Maxim Riabichev
