CAM converter and 2-axis positioner
in PowerPacs
I am trying to use CAM converter with ABB robot and two axis positioner. Eventhough I create controller with 2-axis positioner in the Target Configuration Settings --> External Axis I see only one external axis. Therefore I wonder whether CAM converter can work with 2-external axes?
Thank you.
E.
Thank you.
E.
Since I did not get an answer to this question, once again: does anyone know if it is possible to use two axis positioner with CAM converter?
When I am trying to use two axis positioner - CAM converter does not seem to be able to generate a decent toolpath. However, the same station works if I import externally generated code for two axes positioner. Therefore, I think that my station set up and virtual controller are OK.
Also CAM converter works if I use only a rotary axis.
Any help appreciated!0
