LabView [WebWare Server]
Has anyone used WebWare with NI's LabView? Are there examples on reading and writing to physical inputs and variables?
  • Hello "Charman",
    I`m Labview expericenced with Version 6.0. What do you like to do?
    Could you little bit detail you request? Thank you in advance...
    Best regards
    Kevin
  • Hello, can anybody help me with my problem? I have Labview v 6.0 and ABB IRC5 OPC Server. I need to read variables from IRC 5 to Labview but it doesn't run. I see my variables in OPC Server but the value of variables doesn't change. Where is the problem? I used other OPC client to solve my problem but result is the same. Item quality is still bad.
  • Hi
    Check that you have the option PC Interface in the Controller.
    Per Svensson
    Consat Engineering
  • I've got it. Sure. I see it in the option menu.
  • What Robotware version and IRC5 OPC Server version are you using? You should use the same version of both.
    Russell Drown
  • Please check the basic working of OPC server. I attached a programm there you can check very fass the connection to OPC Server. Main errors are:
    • Missing PC interface on the controller
    • Different Versions on robotcontroller and PC
    • Firewall settings
    • DCOM setting (will be done right if enabled during installation)
    2007-01-19_140025_ClientG.rar
  • Thank you gays, I solved my problem last week. I restarted controler with X-Start, changed IP adress than returned it back and it goes. But now is another problem. The update rate is 1000 ms and I can not set it lower.
