Pick PP problem
Hello to all, I'm not able to create proper system in Picking PP, I got error:
"Controller 1: System IRB_360_3kg_1.13m_Wash_down is missing some of the following RobotWare options:
"709-1 DeviceNet m/s".
"642-1 Prepared for PickMaster" with suboptions "Number of conveyors" and "Number of I/O boards".
To enable simulation with PickMaster, these options must be added to the system. At least one I/O board is required."
I have tried all possible combinations, incuded Devicenet IO boards, 642-1 is already included, I tried with local IO boards, but RobotStudio is still reporting same problem. Did you have similar problem, and how to solve it. I also tried in multimove and non-multimove combination for two robots.
Thanks!
Thanks!
And this is problem that I have with RobotStudio 2020 version trying to use this Pick powerpack, previous error was with RS 6.08. Did anyone have success with using this piece of software:RobotStudio .NET exception: Could not load type 'ABB.Robotics.Controllers.ConnectionType' from assembly 'ABB.Robotics.Controllers.PC, Version=7.0.8504.151, Culture=neutral, PublicKeyToken=null'.============================================Base exception: TypeLoadExceptionCould not load type 'ABB.Robotics.Controllers.ConnectionType' from assembly 'ABB.Robotics.Controllers.PC, Version=7.0.8504.151, Culture=neutral, PublicKeyToken=null'.at PickMasterPP.DataLayer.ControllerOperation.GetController(Guid SystemID)at PickMasterPP.UI.UCManagerPickCtrl.UpdateDataToControls()at PickMasterPP.UI.TabPickMaster.ShowPickCtrlManager()at PickMasterPP.UI.TabPickMaster.<cmd_ExecuteCommand>d__35.MoveNext()--- End of stack trace from previous location where exception was thrown ---at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()0
Try using below combination
RS 2019.5
PkPP 2019.5
Virtual Pickmaster 3.54
Thank for your answer, I just found out that Picking PowerPack works only with DeviceNet fieldbus and DN IO card, why they didn't implement new CTM card I don't know.0
It looks that we have to use PickMaster Twin in order to virtually test system with DSQC 2000.0
