Analog output signal
I have tried to set a analog output signal but is not working as intended. When I set value to eg. 5.00, change to 4.587481.
I have attached properties of the signal.
Hope someone can help. :)
Thanks in advance.
Michael Petersen
  • Hello @michael.petersen I have a question related to the setting you did above, Could you please tell me these numbers max and min indicates what exactly because I am so confused adjusting them of AO.
    Thanks in advace
