[Wish] Add Group attribute on Smart Component properties
Is it possible to add Group attribute on DynamicProperty?
So when it is drawn in RS (Properties pane), the group can be fold as Properties and Signals can.
This should be backward compatible as this attribute is not read on older version of RS.
☑️2024 - RobotStudio® User Group
Hello,To help you understand what I plan, here the xml part (look at added uiGroup attribute):<Properties>
<DynamicProperty name="Status" valueType="System.String" value="" readOnly="true" uiVisible="false">
<Attribute key="AddToDisplayName" value="true"/>
</DynamicProperty>
<DynamicProperty name="Controller" valueType="System.String" uiGroup="Data">
<Attribute key="AutoApply" value="true"/>
<Attribute key="AllowedValues" value="Update" />
</DynamicProperty>
<DynamicProperty name="Task" valueType="System.String" uiGroup="Data">
<Attribute key="AllowedValues" value="" />
</DynamicProperty>
<DynamicProperty name="Module" valueType="System.String" uiGroup="Data">
</DynamicProperty>
<DynamicProperty name="Data" valueType="System.String" uiGroup="Data">
</DynamicProperty>
<DynamicProperty name="ShapeType" valueType="System.String" value="Capsule">
<Attribute key="AllowedValues" value="Capsule;Box"/>
</DynamicProperty>
<DynamicProperty name="ParentAxis" valueType="System.Int32" value="1" uiGroup="Position">
<Attribute key="MinValue" value="0"/>
<Attribute key="MaxValue" value="6"/>
</DynamicProperty>
<DynamicProperty name="CurrentAxis" valueType="ABB.Robotics.Math.Matrix4" uiGroup="Position">
</DynamicProperty>
<DynamicProperty name="Shift" valueType="ABB.Robotics.Math.Matrix4" uiGroup="Position">
</DynamicProperty>
<DynamicProperty name="Radius" valueType="System.Double" value="0.1" uiVisible="true" uiGroup="Size">
<Attribute key="Quantity" value="Length"/>
</DynamicProperty>
<DynamicProperty name="Length" valueType="System.Double" value="0.1" uiGroup="Size">
</DynamicProperty>
<DynamicProperty name="Height" valueType="System.Double" value="0.1" uiVisible="false" uiGroup="Size">
</DynamicProperty>
<DynamicProperty name="Width" valueType="System.Double" value="0.1" uiVisible="false" uiGroup="Size">
</DynamicProperty>
<DynamicProperty name="Color" valueType="ABB.Robotics.Math.Vector3" value="[0,0,0]" uiGroup="Color">
<Attribute key="CustomValidation" value="true"/>
</DynamicProperty>
<DynamicProperty name="Opacity" valueType="System.Int32" value="0" uiGroup="Color">
<Attribute key="MaxValue" value="255"/>
</DynamicProperty>
<DynamicProperty name="GeneratedPart" valueType="ABB.Robotics.RobotStudio.Stations.Part" readOnly="true" uiVisible="false"/>
<DynamicProperty name="ShowAtOrigin" valueType="System.Boolean" value="false"/>
<DynamicProperty name="MakeAxisFrame" valueType="System.Boolean" value="false"/>
<DynamicProperty name="IsSelectable" valueType="System.Boolean" value="true"/>
</Properties>What it should look:
What it looks for older version:
☑️2024 - RobotStudio® User Group2 -
Hello Denis,
I'll forward this to R&D.
Hello Denis,
This would really improve the SmartComponents usage, good idea!
Hello all,
I'm happy to announce that this feature request will be implemented in the 2020.4 release of RobotStudio.
Thanks for the suggestion!
