No templates in VisualStudio (Creating new Robostudio AddIn)
steph
Hello und Grüezi,
like a lot of other beginners I try to implement my own RobotStudio Add-In. Point of start: "Creating a RobotStudio Add-In"
I downloaded and installed the file "RobotStudio SDK.6.08.8148.0134.exe" (with admin-priviledges).
After installation of the RobotStudio SDK I expected to have "new templates" in my Visual Studio 2017:
But unfortunately there are no new templates.
Does anybody face the same problem?
Atm I am able to create normal VisualStudio-Projects and use all important ABB references (I mean all *.dll-files like "using ABB.Robotics.RobotStudio.Environment;")
Therefore I can execute many examples of ABB like getting controller list and so on but I don't know how to create a own Add-In (in RobotStudio) without having these templates available.
Recap:
Just wanna have a new Ribbon called "myRibbon" with a Button called: "Hello-World". After pressing the button there should appear a MessageBox with HelloWorld.
Setup:
RobotStudio 6.07.01 (64-Bit)
Microsoft VisualStudio 2017
Does anybody see my fault?
Thanks in advance
steph
"Open visual Studio and select New Project.... From the list of available templates, select either RobotStudio 6.03 Empty Add-in and choose a name for the project."
Recap:
Setup:
Thanks in advance
steph
I got VS 2019 and had the same problem.
Then I found out, thet I could copy the templates from:
C:\Program Files (x86)\ABB Industrial IT\Robotics IT\SDK\RobotStudio SDK 6.08\ProjectTemplates
to
<User>\Documents\Visual Studio 2019\Templates\ProjectTemplates\Visual C#
1 -
The location of the template files for 2020 RS SDK: C:\Program Files (x86)\ABB\SDK\RobotStudio 2020 SDK\ProjectTemplates
- 365 IRC5
- 84 OmniCore
