How to delete module attribute
innebandy
I've been testing RAPID module declarations by changing attributes. And I found a RAPID manual saying "READONLY: The module cannot be modified, but the attribute can be removed." But there is no way to remove the attribute using the FlexPendant. I could find a way. How can I do that on the FlexPendant without using RobotStudio?
Save the module to USB drive and edit in a text editor.0
Yeah, I know that is possible. Then, what is the difference between VIEWONLY and READONLY? That's my question.0
- 365 IRC5
