Smartcomponent Signals & Properties acting weird
EricH
Does someone know how they work internally, because strange things happen with them. For example after a LogicExpression is the Result 0 on the output, but it is at the next gate 1 in the input. So that's definitely not good.
I'm experiencing similar weird behavior, but other way around, result is 1, start is 0
Are you getting this behavior with the simulation started or stopped?—Maxim RiabichevPC Software Support Engineer0
It happens with simulation started and remains at stop.
@EricH the SC in question, the Logic_PP_Conv, how does it look "on the inside"?—Maxim RiabichevPC Software Support Engineer0
I changed it, so it works now again.The Start signal was going directly on a SRLatch . At the moment it looks like this:0
If you want to look at the source code for each built-in SC, please take a look at this post: https://forums.robotstudio.com/discussion/12091/finding-example-code-for-building-smartcomponents—Maxim RiabichevPC Software Support Engineer0
Same issue happened again, now between two AND-Gates.There is an error message: Illegal I/O connection detected: signal 'InputA' set twice in same context.I don't know at which smartComponent that happened and what caused the error.Post edited by EricH on0
Hello Eric,
I believe that this thread is related/relevant to yours: https://forums.robotstudio.com/discussion/12318/unexpected-pulses-in-smart-components-outputs
Post edited by Maxim Riabichev on—Maxim RiabichevPC Software Support Engineer0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
