ABB S4C+ Restore (QuickTeach) ( error12236)
                    paulfile
                    Hello
                        I'm simulating with the QuickTeach (ABB robot simulasyon) program.I took a backup of the system.An error has occurred during the restore process.
Status 12236
Error during the restore of task write error.
12236 Restore Error
I did not change the backup file.Why does this error occur?
How can I restore?
            Hello,You want to restore a real robot into a virtual one?What I suggest is to make a backup of clean virtual controller then merge with real one.Pay attention in backinfo.txt file with folder character "\" and "/".Make sure that no flp1:/ exist in it too.☑️2024 - RobotStudio® User Group0
            not real robot, just simulation. I did not restore. I installed EIO from parameter settings. problem solved.grateful for your comments. Thank you 0 0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
