[Wish] Station Logic Export & IOConnection
Is it possible to add "Allow cyclic connection" properties in exported to rsxml file for each IOConnection?
And add a column for this in "I/O Connections" list.
In same time, if an option could be added to check it by default when connections are created.
@Maxim Riabichev : Could you do something for that?
Could you elaborate on what problem your wish would solve and perhaps show more clearly how you would like it to behave/look like?
—Maxim RiabichevPC Software Support Engineer -
Hello,In Station Logic / Signal and Connections / I/O Connections list, you don't have "Allow cyclic connection" column.Nether in rsxml exported file:<Station name="" xmlns="urn:abb-robotics-robotstudio-graphiccomponent">
<Signals>
<IOSignal name="AnalInput" signalType="AnalogInput" value="0" />
</Signals>
<Connections>
<IOConnection source="AnalInput" target="Counter.Count" />
</Connections>
<GraphicComponents>
<EmbeddedLibrary source="%ABBLIBRARY%\Components\Counter.rslib" name="Counter">
<PropertyValue name="Count" value="0" />
<SignalValue name="Increase" value="0" />
<SignalValue name="Decrease" value="0" />
<SignalValue name="Reset" value="0" />
</EmbeddedLibrary>
</GraphicComponents>
</Station>Should be:<IOConnection source="AnalInput" target="Counter.Count" allowcc="True" />For the option, I hope its clear. -
Very nice, I'll look into it!
Thank you.—Maxim RiabichevPC Software Support Engineer -
Hello Denis,
I'm glad to inform you that this wish has been granted and implemented in RobotStudio version 2020.2
Thank you for trying to make the product better.
Have a great day!
Hello,Still missing column in I/O Connection table.
Hello Denis,
Since it is possible to check the Allow cyclic connection via the Edit-window, R&D has decided to prioritize other functionality requests at this time.
Perhaps we can return to this request in the future.
Thanks!—Maxim RiabichevPC Software Support Engineer
- 10.1K All Categories
- 5.2K RobotStudio
- 323 UpFeed
- 8 Tutorials
- 1 RobotApps
- 273 PowerPacs
- 401 RobotStudio S4
- 1.7K Developer Tools
- 224 ScreenMaker
- 2.6K Robot Controller
- 206 IRC5
- 26 OmniCore
- 5 RCS (Realistic Controller Simulation)
- 3 RobotStudio AR Viewer
- 621 RAPID Programming
- 14 Wizard Easy Programming
- 98 Collaborative Robots
- 3 Job listings
