Determine confdata and extjoint based on pose with RAPID
HenrikB
Hi, I am working on a bin picking system using a 3D camera
and I’m wondering how I can determine confdata(cf1,cf4,cf6 and cfx) and
extjoint based on the pose of the object with RAPID? When using robotstudio I
can create a target by inputting the pose and these values are calculated in
robtarget variable, so I’m thinking there must be a way to do this in RAPID, maybe
with a list of available configurations that the program can iterate through.
Thanks for any help.
I would use the function CalcJointT() to convert the robtarget into a jointtarget, then, examine the joint angles and use them to figure out the confdata.Lee Justice0
I have looked at CalcJointT() but that would require an initial guess for confdata and extjoint that, if incorrect, will cause an error. Therefor I am looking to avoid that if possible.
Try just writing in all zeroes.Lee Justice0
Hello,It's not so easy Bin Picking.For me I take pose send by camera then only apply confdata for axis 1 depending where position is.Then I calculate jointtarget with CalcJointT and calculate a robtaget with it. (in same time it say me if the position is accessible). So confdata is for one solution.After, I check axis 4 and 6 to not wrist sheath. If needed I turn them in confdata.Check if axis 5 is not too closed (gripper may collide with axis 4) depending axis 6.And at end use my open-sourced module to check if robot don't collide with environement.You can see the result in RobotStudio with the Component.
☑️2024 - RobotStudio® User Group0
- 345 IRC5
- 73 OmniCore
- 843 RAPID Programming
- 20 AppStudio
