[Wish] Station Logic Export & IOConnection
Is it possible to add "Allow cyclic connection" properties in exported to rsxml file for each IOConnection?
And add a column for this in "I/O Connections" list.
In same time, if an option could be added to check it by default when connections are created.
☑️2024 - RobotStudio® User Group
Could you elaborate on what problem your wish would solve and perhaps show more clearly how you would like it to behave/look like?
Hello,In Station Logic / Signal and Connections / I/O Connections list, you don't have "Allow cyclic connection" column.
Nether in rsxml exported file:<Station name="" xmlns="urn:abb-robotics-robotstudio-graphiccomponent">
<Signals>
<IOSignal name="AnalInput" signalType="AnalogInput" value="0" />
</Signals>
<Connections>
<IOConnection source="AnalInput" target="Counter.Count" />
</Connections>
<GraphicComponents>
<EmbeddedLibrary source="%ABBLIBRARY%\Components\Counter.rslib" name="Counter">
<PropertyValue name="Count" value="0" />
<SignalValue name="Increase" value="0" />
<SignalValue name="Decrease" value="0" />
<SignalValue name="Reset" value="0" />
</EmbeddedLibrary>
</GraphicComponents>
</Station>Should be:<IOConnection source="AnalInput" target="Counter.Count" allowcc="True" />For the option, I hope its clear.☑️2024 - RobotStudio® User Group0 -
Very nice, I'll look into it!
Thank you.
Hello Denis,
I'm glad to inform you that this wish has been granted and implemented in RobotStudio version 2020.2
Thank you for trying to make the product better.
Have a great day!
Hello,Still missing column in I/O Connection table.☑️2024 - RobotStudio® User Group0
Hello Denis,
Since it is possible to check the Allow cyclic connection via the Edit-window, R&D has decided to prioritize other functionality requests at this time.
Perhaps we can return to this request in the future.
Thanks!
- 858 RAPID Programming
