MoveLDO set multiple output
sort
How can I set multiple outputs with one MovelDo instruction.
I think that using more MoveLDO instructions with the same target is not the best practice.
Thank you for your help
You could instead use MoveLGO and set a grouped output of signals.
Daniel0 -
Read up on TriggL, TriggJ and associated instructions.Lee Justice0
You can try something like this maybe.
PROC MoveLDo_Multi(robtarget mvldo1,VAR signaldo mvldosig1,num mvldonum1,VAR signaldo mvldosig2,num mvldonum2,VAR signaldo mvldosig3,num mvldonum3,speeddata mvldospeed,zonedata mvldozone,PERS tooldata mvldotool,\PERS wobjdata mvldowobj) MoveLDO mvldo1,mvldospeed,mvldozone,mvldotool,mvldosig1,mvldonum1; MoveLDO mvldo1,mvldospeed,mvldozone,mvldotool,mvldosig2,mvldonum2; MoveLDO mvldo1,mvldospeed,mvldozone,mvldotool,mvldosig3,mvldonum3; ENDPROC PROC MoveLDo_Test() pCurrent:=CRobT(); MoveLDo_Multi pCurrent,doTT_LeftRotate,1,doTT_RightRotate,1,doAir_1,1,v300,fine,tWG; WaitTime 10; pCurrent:=Offs(pCurrent,100,100,-500); MoveLDo_Multi pCurrent,doTT_LeftRotate,0,doTT_RightRotate,0,doAir_1,0,v300,fine,tWG; ENDPROC
Hello,You can use MoveLSync. This call a procedure when get into finish zone.☑️2024 - RobotStudio® User Group0
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
