read value of AS1, GS1, ES1 - read external safety status
I would like to read the value of AS1 and GS1 but I don't know how to do that. I want to do this for the HMI.
I tried to use cross connection or direct rapid read but it's not work. Also, I can't see theses signals inSystem Output... I only see : EmergencyStop : it's work only for internal emergency stop...
I use Auto Stop for fence open and General Stop for external emergency stop. I want to see on my HMI if the robot is stopped for fence open or emergency stop...
Thanks you
Hello,Which version of RobotWare do you have?☑️2024 - RobotStudio® User Group0
Did you try something like this:EIO_CROSS:
-Name "C_SYSTEM_AS" -Res "SYSTEM_AS" -Act1 "AS1" -Oper1 "OR" -Act2 "AS2"
-Name "C_SYSTEM_AUTO" -Res "SYSTEM_AUTO" -Act1 "AUTO1" -Oper1 "OR" -Act2 "AUTO2"
-Name "C_SYSTEM_DRV1" -Res "SYSTEM_DRV1" -Act1 "DRV1LIM1" -Oper1 "AND" -Act2 "DRV1LIM2"
I have to recommend that external e-stop be wired to robot e-stop, not general stop. They are not the same except that both have effect in auto and teach. General stop is by default soft, e-stop is not. Also, e-stop requires a reset either local with motor on button or system input specific to reset e-stop.Lee Justice0
- 365 IRC5
- 84 OmniCore
