Associating Libraries to Mediapools
DanS
Is it possible to associate a user created Mediapool with a user created RS Library? I would like a specific library loaded each time I use an external axis Mediapool.
Hi DanS,
Yes that should be possible with a little bit of XML editing.
When you start a controller with a mechanical unit that RS doesn't recognize you'll encounter this dialog:
What you need to do is to add the mechunit type to the mapping file <Program Files>ABB Industrial ITRobotics ITRobotStudioLibraryMappingMechunitLibraryMap.xml.
In this case it would look like this:
<Mechunit type="ROB1_260" library="RobotsIRB260_30_150__01.rslib"/>
The path is relative to the RobotStudioABB Library directory so you would have to copy your library there.
regards,
Johannes
Johannes Weiman
Thank you sir!
I don't suppose it's also possible to present a list of libraries to select from? ...say for multiple L positioners as an example.
Just add several mechunit tags with the same type but paths to different libraries.
And when you press OK it will show you a list with all the libraries.Per Svensson
Consat Engineering0
- 5.4K RobotStudio
- 381 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 737 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
