RS Add-in memory consumption
chmalan
Hi all,
I create a lot of target by a RS add-in. it works fine, but the memory consumption is very high and RS will free it only on exit.
I destroy every object at the end of the functions and i can't see it in the watchlist. After two complete calculated parts RS needs about 1 GB RAM or more.
Is there a function the free up the memory without closing RS?
What happens if you set no of undo steps to 0?
menu toolsoptions and the misc tab.Per Svensson
Consat Engineering0 -
I set the no of undo steps to 0 and make a few tests. During calculating RS requires more RAM until 1.6 GB physical memory is allocated and then the following error occures:
RS have to free up the memory and destroy the objects they aren't required no more.
Is there any function to force RS to do that?
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
