attaching tool to an adapter
Armbross
https://gofile.io/d/JmxcrX
Try right clicking the entire tool assembly > modify > set local origin.0
You mean the gripper. because there's no modify option0
Yes the gripper. If you get stuck, refer to this video, it helped me in the past.
https://www.youtube.com/watch?v=JOfzHlKB-0I&feature=emb_title
I have referred to that video already, but it doesn't help me because I'm unable to use frame for tcp information0
I have recorded a "quick and dirty" video tutorial based on this problem.
I make some mistakes but I show how to correct them. Perhaps this can be useful for those who end up making the same mistakeshttps://youtu.be/yhX9iCWE0To
Edit: Reviewing the video I already see I've made mistake (said something wrong) regarding why the tool was up in the air. It is not because of the Tooldata values, it's because of where it is placed when the mechanism was compiled.Post edited by Maxim Riabichev on—Maxim RiabichevPC Software Support Engineer1 -
wow thanks for the videos0
- 345 IRC5
- 73 OmniCore
- 843 RAPID Programming
- 20 AppStudio
