Buuls eye
Is it possible to test the bulls eye option in rs. 5.07. I can select the option while config the VC but can i then test the way i works. I Whant too use it on other tools then Weld guns
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
  • Hi Klaus,
    You would need to simulate (in the I/O) the tool breaking the beam. So it would not be a very good test of what would happen in the real world.
